Multiple Hubs - Local Storage
  • 1 Reply
  • 604 Views
antuk
Hi all,
Can anyone shed any light on what happens if you install a second hub for the Ultra 2 while using local storage, will the camera store the video on whichever hub its connected to, and does this work seamlessly in the app or do I need to switch between hubs to see the footage?
Is it possible to direct all the video to be stored on the main hub and just use the secondary hub as a range extender?
Thanks,
Anthony
No.  The local recordings are made on the base the camera is connected to.
FWIW, I think it would be nice if the app had an option to show the local recordings in feed.
  • 1 Reply
  • 605 Views
