Is the ultra cameras compatible with pro 4s?
  • 5 Replies
  • 1090 Views
5 REPLIES 5
Not sure what you mean by "compatible", but you can add pro 4 camera to your system.
Bscheffers8228
If I have arlo pro 4 and wanted to add a ultra would they work together?
Again, it would be helpful to know what you mean.  In most cases the cameras work independently.
But you can trigger an Ultra recording when a Pro 4 detects motion, and vice-versa.
Bscheffers8228
Ok so if I open the arlo app to check the cameras all the pro 4s and the ultra will show up on the app at the same time?
Yes
  • 5 Replies
  • 1091 Views
