@KevP wrote:
I'm in the UK and have tried phoning between 9am and 5pm.
9 am - 5 pm in the UK is 1 am - 9 am US pacific time. Phone support isn't available until about 2 pm your time ( 6 am in California).
I'm tagging the mods ( @JamesC , @ShayneS , @BrookeN ) in hopes they can facilitate/assist.
A blinking amber light in your hub likely is telling you there is a camera connection error:
As far as firmware updates go, they roll out slowly (and there is more lag in Europe, due to the Verisure/Arlo partnership). There is no way to speed that up. There is a firmware update function in the app, but it isn't very useful in practice.
Resetting the base is not the best idea, as that will require you to remove all the cameras from the account and add them all back again. If you want to reset something, try resetting the problem camera. You'd first remove the camera from the account. Then hold down the sync button inside the camera housing until the camera LED flashed amber three times. Then add the camera back to the account.
Are you using phone support between 6 am and 6 pm US pacific time?
@KevP wrote:
one of my cameras stops working
Are you able to live-stream the camera? If not, is the camera showing up as off-line? Or does the app just hang when you try to live-stream?
What have you tried to do to fix it?
I'd start with removing/reinserting the battery (which reboots the camera). If you don't see the normal blue LED behavior, then the camera might need to be charged. You can try swapping batteries with the other camera to see if you have an issue with the power circuitry in the camera (and also rule out a battery problem).
If that doesn't help, I'd restart the base. Then try bringing the camera indoors, and see if it resumes normal operation when closer to the base.
One final step that can help is to remove the camera from the account. Then do the hardware reset (holding down the sync button until the camera LED flashes amber). Then add the camera back.
Arlo Ultra 2
Prima di acquistare
