How much memory can the Arlo Ultra 2 hold
How how much SD memory can the Arlo Ultra 2 hold and what type. I’d figure they had this in product specs easily findable but I cannot find it. Also how much and what kind of SD does base station take?
From the manual,
https://www.arlo.com/en-us/images/Documents/ArloUltra/Arlo_Ultra_User_Manual_US_2.pdf
Your SmartHub accepts micro SD cards, SDHC or SDXC only, file format FAT32. The Arlo app displays a message to let you know if you need to format the SD card.
The SmartHub can format the SD card.
Your SmartHub accepts SDHC or SDXC microSD cards.
We recommend using microSD cards with a minimum of 16 GB capacity, Speed Class 10, UHS-!, V10.
Your Arlo SmartHub supports up to Class 10 UHS-3 V90.
Other users say 256GB works ok but 512GB may have issues.
Just to be clear, the microSD card is in the VMB5000 smarthub, not the camera. If you use the camera with any other compatible base, you need to use USB storage.
I use 128 GB myself. As @Dannybear says, several users have reported success with 512 GB. I don't recall seeing any posts from users who have successfully used 1 TB or 2 TB.
Arlo Ultra 2
Prima di acquistare
