How do I review Ultra 2 SD card footage in app?
When I record, nothing goes to the SD card. The setting local setting are:
SD Recording ON
Best Local Recording ON
SD Card Status GOOD
Available storage 59.46gb
When I record on any camera, nothing appears on the SD card. In the library the option is to download.
If you are talking about what is on the SD card yes you have to download each one on the app or view the card in a computer to view. Not ideal I know. It is the same on the Pro3 hub. It explains it near the bottom of this page.
What is Direct Storage Access and how do I use it? (arlo.com)
Arlo Ultra 2
Prima di acquistare
