Excessive motion detection warnings….
  • 1 Reply
  • 444 Views
DDevlinJr
I have several Arlo cameras, but on one, I’m getting excessive motion detection warnings, when absolutely nothing is happening in front of the camera and, in fact, no clips are being created. Help.
Excessive notifications/recordings may be due to the sun's IR being reflected off leaves, trees/bushes, passing cars, etc. This can happen as the sun's angle changes over time and then go away as the angle changes more. You can reposition the camera to eliminate those objects from the camera view as much as possible and/or reduce motion sensitivity while still getting the coverage you need.
  • 1 Reply
  • 445 Views
