Downloads will not play.
  • 8 Replies
  • 1189 Views
Re_zeekay
Videos will download from the cloud, but are not playable on Android system. Error says unable to play video.
8 REPLIES 8
What device are you using, and what version of Android is it running?
Re_zeekay
Currently Nokia XR20 on Android 12.
Seems to me that 4K HEVC should play back on that device.  Does this happen with every Ultra recording, or just some?
Here is a test file that you could attempt to play on the phone:  https://www.elecard.com/storage/video/Elecard_about_Tomsk_part1_HEVC_UHD.mp4
There have been occasional issues with videos having some sort of corruption that prevents them from playing. Install the VLC app which will play all but the worst corrupted files.
Re_zeekay
That test video file does not play either. You can view recordings in the Arlo app with no issues. It's only when you download them for saving or sharing purposes that they won't play.
That is useful info, it says that the phone does support HEVC 4K playback.
This suggests that the problem is the player you are using in the phone.  Nothing Arlo can do about that. If it's the one that came with the phone, you could maybe reach out to Nokia.  Or look for a substitute player app.
Re_zeekay
Files automatically download to google photos app.
Re_zeekay
It must be an issue with google photos app, as they play fine on my laptop.
  • 8 Replies
  • 1190 Views
