Does’nt record
Hi
My arlo hub is continously maybe disconnecting?
My camera (ultra 2) randomly stops recording, but still gives updates about movings, and when i go to history, nothing is stored in the app.
My hub is connected directly to the router.
This is intermittent???
Does it resume recording on it's own, or are you taking some action (restarting the hub, removing/reinserting the camera battery, etc)?
Hi Stephen
thanks for your reply, i have to restart the hub every time.
yes, its intermittent, and today i discovered it had not filmed since sunday.
Can you livestream the cameras after you notice the problem (but before you restart the hub)?
No, i can’t livestream until i restart the hub
Do you only have the one camera?
If you have more than one, can you livestream the others?
If not, have you tried removing/reinserting the camera battery (leaving the hub alone)???
I have 2 cameras but the other cam is currently too far away from the hub to have connection(that’s another problem 😵💫)
I haven’t tried taking the battery out yet, do you think its the camera playing tricks?
Well, it's either the hub or the camera.
If you can bring the 2nd camera inside for a test (ideally around 10 feet from the base station), then you could see if you can livestream the second camera when the first becomes non-responsive.
I am having the exact same issue. I have 2 Ultras and floodlight camera. It started over 2 weeks ago where the camera wouldn't capture video but yet send notifications. You can see the orange icon indicate sound is being picked up or motion within the app looking at Device tab but no video. If you click live it says Connecting but never connects for the 2 Ultras. I took the batteries out and checked for firmware and resync they lasted 1 day before going back to same pattern. I even checked on Android since my normal is iPhone and the app gets glitch. Still nothing. Paging for subscription and can't check videos.
Are you still seeing this same behavior?
Yes, 1 camera is still actively behaving this way. The other was reset again and has maintained normal function the past week.
Please contact support. Within the app on your mobile device click on the silhouette on the top left ~ support center ~ the device that you are needing assistance with then choose the issue.
Arlo Ultra 2
Prima di acquistare
