Can anyone tell me the difference between Arlo Pro Smart Hub and Ultra 2 Smart Hub... besides $50?
Thank you.
The VMB5000 is dual band, the VMB4540 is only 2.4 ghz. That only matters if you have an Arlo camera with a 5 ghz radio (and if that camera is close enough to the base for 5 ghz to be a better option).
It also uses a microSD card for storage instead of USB.
Thank you.
Arlo Ultra 2
Prima di acquistare
