Connection a distance hub
- Bonjour
- Comment ouvrir les ports pour visualiser a distance les vidéos contenues dans mon hub?
I am thinking you are talking about forwarding ports for remote access to local storage.
If that is the case, you need to look in your router manual for that.
Arlo Ultra 2
Prima di acquistare
