Charging solutions
I’ve had the cameras installed for 2 weeks, they’re getting to the point where they need recharging.
Currently, the only way I can see to recharging the ultra 2 is by removing the entire camera from the mounts and using the included charger. I did not see anyway to recharge the batteries by removing the camera from the casing and keeping the fixed positions I setup.
The issue goes to reinstalling them and having all my zones slightly altered. It is not convenient to run an extension to each camera for 4 hours once every two weeks given their locations. The solar stations also would not work where I have 3 of the cams - also paying another $280 for 4 of them seems unreasonable.
Wondering if anyone had figured out a solution to this engineering over site by Arlo?
If you use the external charger with an additional battery you can just pop the camera out and swap batteries. Otherwise, maybe the outdoor charging cable or solar panel would be useful.
Arlo Ultra 2
Prima di acquistare
