Ceiling install for Ultra 2. Do I use magnetic mounts?
  • 1137 Views
Nedns
I am a bit confused on what mounts I need to order to install Ultra 2 on the ceiling.
There is a ceiling adapter in accessories, but in Amazon, it shows as not compatible with Ultra 2.
So, do I just use the magnetic mounts instead ? for the ceiling ?
Thanks !
dcfox1
There is a ceiling mount for the Ultra and others that might work in the Accessories page on the Arlo web site.
You'll only be able to aim the cameras straight down if you use the magnetic mounts.
The screw threads are standard, so there are lots of mounts you could use.  The regular Arlo screw mount might do: https://www.amazon.com/BFYTN-Security-Ceiling-Adjustable-Compatible/dp/B075DQJV5N  Though it depends on the ceiling (these wouldn't be a good option for a drop ceiling), and the angle you need.
Nedns
Thanks for the info. That opens up the possibilities.
The ceiling is concrete and I need about 110 degree angle, so this looks like the right option.
  • 1138 Views
