  • 1441 Views
colin1892
Hello, i currently have an arlo pro 3 and 2 arlo pro 2 1080p cameras with the basestation that came with the arlo pro 2, if i was to buy 2 arlo ultra 2 cameras with the basestation that comes with it, can i also use the arlo pro 3 connected to the same basestation and then i can sell the old one and the cameras do you think they will screw into the same brackets then the 1080p ones where in? thanks
The smarthubs (both the VMB5000 and the VMB4500) will support your existing cameras.
So you can move them over to the new base and sell the old one. If you do, make sure you remove the base from your account.
Though you might get better performance if you just use both bases.  There is a limit on how many streams a base station can handle simultaneously (I think it's 5).
Note that you'll be able to take advantage of the free 7-day cloud recording on the Pro 2s either way.  As you likely already know, you'll need a paid subscription for the Ultras to get cloud recording (same as the Pro 3s).
The Ultras use the same magnetic mounts as the Pro 3s, so they aren't compatible with the Pro 2 magnetic mount.
But the screw threads are standard, so almost any screw mount is compatible with all Arlo cameras.
colin1892
many thanks for taking the time to reply Stephen, can i just confirm just to be sure that ultra 2 4k will work with my old basestation, (the one that came with my arlo pro 2 basestation) sorry if i sound confused
Your earlier post said that you wanted to sell the old base, not the new one.
Your old base might not be compatible, and there are some features in the new ones that you would lose.  So I recommend using the new base with the Ultras at least.
But this article answers your followup question:  https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
The VMB4000 or above supports the Ultra 2, the older bases dont'.
  • 1442 Views
