Camera shows black during live stream
I suggest swapping locations with one of the other two, and see if the problem moves with the camera or stays at the location.
If it moves with the camera, then you could consider exchanging with the seller, or contact arlo support using the app. You'll find a phone option there.
I have not seen the artifact since so no swapping yet.
I still have ONE other defect (in my previous post I conflated them because I thought they were related; yet since one of the problems is still present and the other is not; I can only assume they are not related).
Anyway, the other defect is that everytime I log into arlo.netgear.com one of my cameras (it is the same camera and it happens every time - consistent) is showing as unavailable. Due to previously stated issues that are manifesting, I have rebooted and restarted the hub, cameras, and app,,, still this camera shows as offline on the website (read: it is active in the app; and all other cameras are active in both places).
I do NOT know how to insert an image but it has the default screen when a camera is offline in the app.
You should be using my.arlo.com (Arlo hasn't been part of Netgear since 2018). But arlo.netgear.com should be redirecting you to my.arlo.com anyway.
@Dbmdude wrote:one of my cameras (it is the same camera and it happens every time - consistent) is showing as unavailable.
Have you tried a different browser?
There are two ways - there is a paper clip icon below the post text box that can add screenshot, and there is a camera icon above the text box that can embed a screenshot into your post.
Both require the extension to be either png or jpg. If your screenshot is jpeg, then you need to rename the extension to jpg.
Embedded screenshots won't show up right away - mods need to approve all embedded images before they are shown.
Arlo Ultra 2
Prima di acquistare
