Camera capability
Hi I’m curious on if the arlo ultra 2 or pro 4 could be set up to film our house being built in Florida while we are in Michigan? We would you the solar charger to keep it charged
Yes you can add them to your account. The Ultra2 needs to be connected to a Hub and the Pro4 can connect to wifi or a hub. I would assume there is a lot of activity on a construction site to record so not sure if a Solar Panel will keep up for the duration especially in several cloudy days in a row depending on activity. You may want someone there to charge the battery if it doesn't keep up there in case. The outdoor charging cable would keep up no matter what once you get electric. Also, obviously you would need a subscription for cloud recordings.
Arlo Ultra 2
Prima di acquistare
