Ucucucucc,
Could you provide more information about what you are experiencing? What is preventing you from charging the batteries? Are you seeing any error messages within the Arlo mobile app?
@Ucucucucc wrote:
the batteries simply do not charge, doesnt matter if i change batteries on the cameras or clean the adapter - using your original one. had this problem since day one.nothing comes up in the app
Are they completely dead?
they have a little left in them but they do not charge when connected with cable. as one of the has less than 10% left i want to get them fully charged before remounting them on the house
This procedure is for the Pro / Pro 2 cameras, but is worth trying with the Ultras.
Also, might be worth trying a different charger (or outlet).
Hi Stephen,
I have been doing exactly the procedure as described in the link and usually it worked out after a few times and the battery starts charging - but this time nothing happens. I have not tried another charger bit tried quite a few outlets.
Arlo Ultra 2
Prima di acquistare
