Arlo solar panel fault
My camera goes off line when connected to a solar panel. Have connected to another panel and it charges fine it’s just that one panel… about 3 months old… could it be a faulty panel ?
sounds like it. Have you tried connecting a different camera to that panel?
Yes same result.
@sonic350 wrote:
Yes same result.
Then I think it is the panel. Check the warranty status, and see if you are eligible for a replacement.
Arlo Ultra 2
Prima di acquistare
