Arlo Ultra 2 vrs Arlo Ulta
Aloha, How can I tell the difference between an Arlo Ultra and an Arlo Ultra2.. Thanks for any help.
Unfortunately, the part numbers are the same (VMC5040) - I believe the suffix for the Ultra 2 is -200xxx, while the Ultra is -100xxx. No idea why Arlo did that.
You can try opening the camera and removing the battery - looking at the label inside. (I'm not sure if that is enough to tell you).
Arlo Ultra 2
Prima di acquistare
