Arlo Ultra 2 motion detection
Hi everyone,
I just bought the Arlo Ultra 2 and have a question about motion detection.
Is motion detection based only off the IR sensor or can it also use pixel based movement?
I’ve setup activity zones but the detection is happening outside of that zone on my neighbours property, which I don’t want to happen.
As it’s my first time using this product I’m not sure if maybe I’ve set it up wrong?
Can anyone share how they’ve got their camera’s setup to get the best recording.
Thanks.
Motion detection itself is only from the IR sensor.
Activity zones are based on pixel processing - that is done in the Arlo Cloud if the cameras are on battery power. Although it doesn't take much motion inside the zone (and compression artifacts also can result in the system deciding motion is inside the zone).
You can try adjusting the field of view a bit, or maybe adjusting the motion sensitivity downwards. Use the motion detection test to make sure you don't lower the sensitivity too much. https://kb.arlo.com/41/How-do-I-change-the-motion-sensitivity-on-my-Arlo-camera
Arlo Ultra 2
Prima di acquistare
