Arlo Ultra 2 fog on cam lens
Hi,
what could be the reason of fog or something disscolered the inside of lense as shown in picture. It scould be black but is now moor white ish
#ultra #issue
Assuming you mean that there's that white-ish ring, as indicated by the arrow, that's not the lens. I can't say whether it's always been that way or has changed but it's nothing to be concerned with. If it changed over time, it may be that the plastic (I assume) has been in contact with strong sun's rays causing this. It won't affect image quality.
Arlo Ultra 2
Prima di acquistare
