Arlo Ultra 2 WiFi Question
  • 1 Reply
  • 1061 Views
arnolyuna
Does the Arlo Ultra 2 require WiFi connection to a 2.4GHz band, or is it able to connect to 5.0GHz?
If only able to connect to 2.4GHz, if I add a Base Station that is hardwired to my router, would that then solve/eliminate the issue of having to connect to the 2.4GHz band?
Thanks!
The Ultras can connect to either 2.4 or 5 GHz but that requires the use of a VMB5000 SmartHub. The cameras have to connect to a base or hub, not to your WiFi, and the 5000 is the only hub that supports both bands.
  • 1 Reply
  • 1062 Views
