Arlo Ultra 2 Smart Hub
My smart hub will not activate. The blue led in front are constant, but the Base Station could not be discovered.
Try these things:
- Press and hold the reset button for >15 seconds until the LED starts flashing amber. Let the hub reboot (~2 minutes) and try again.
- If using a VPN, disconnect it. You have to be on the same network to set the hub up.
- Make sure you're on your WiFi and not cell service.
- Try the web client (my.arlo.com)
Arlo Ultra 2
Prima di acquistare
