Arlo Ultra 2 Cameras - Base station 5000
  • 2 Replies
  • 939 Views
Cornell464
I am using an Orbi router with  2-networks (1) home network, (2) guest network.  I would like to setup my Arlo ultra 2 camera system on the guest network.  I have renamed the guest network and also applied a new password.
Now I just need the steps in sequential order to move my cameras from the home network to the guest network.
Any advice would be appreciated!
The ultras don't use your wifi at all, they connect directly to your VMB5000 - which connects to your Orbi via ethernet.  So this can't be done.
Can you let us know your intent?
Since the Ultras use a hub, they're not connected to your WiFi in the first place. The hub uses the Ethernet cable to access the Internet so no WiFi to your home network is needed.
