Arlo Camera Screw Mount Hole
  • 1 Reply
  • 1377 Views
  • 1 In Conversation
TUKhS5Ays4Ez
How can I get a few spare metal screw mount holes for my dozen plus arlo cameras?  I have a problem with the metal in the screw mount hole coming out and getting stuck to univeral mounts from OkeMeeo (pole/tree) and Wasserstein (gutter) when they need replacing or I decide to swap out 4k and 2k cameras at a specific location.  This is a much bigger problem with the gutter mounts which I stopped using, but still a problem with OkeMeeo.  On a tangential topic, I have a problem with OkeMeeo mounts deteriorating after 2 years of use due due to heat and/or humidity in Florida.  Is there a more durable weather resistant pole/tree mount that works better than OkeMeeo?
I've bought on amazon including https://www.amazon.com/dp/B08LVKKPH2?ref=ppx_yo2ov_dt_b_product_details&th=1 and https://www.amazon.com/gp/product/B07L9WPT62/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1.
TUKhS5Ays4Ez
I found another community member who had a similar issue: https://community.arlo.com/t5/Arlo-Pro/Arlo-Pro-Camera-Metal-Screw-Housing-Detached/m-p/1638729#M447...
However, he was able to RMA the cameras.  I have figured out how to put the metal screw housing back in before, but still need to get a few spares since it is such a common problem as my mounts are degrading from the weather.
  • 1 Reply
  • 1378 Views
  • 1 In Conversation
