@booxman wrote:
I’m referring to Item No. VMA5000C-100NAS, the 8’ Arlo charging cable accessory.
Ok. That's the magnetic cable - the specs are 5v/2a (as I said above).
@booxman wrote:
Also, what difference would it make if the power adapter was 5v or 9v? I’ve been using the cable and adapter (plugged in inside) that came with the camera for a month and it works beautifully. Why 9v for outside?
Just to clarify - the dual voltage charger I referenced above was for the Pro 2 charger.
As far as the 9v outdoor charger goes - the short answer is that they went to a higher voltage because the cable is so much longer.
There is a voltage drop in the cable, because of the resistance of the wires. This drop reduces the delivered power to the camera. The longer the cable, the more resistance - and the higher the voltage drop (and power loss) becomes.
Using a higher voltage (with lower amperage) reduces the power loss due to the cable resistance. That's why long-distance power transmission lines run at much higher voltages than the power coming into your home.
@booxman wrote:
What is the voltage of the power adapter that comes with the Arlo 8-ft. Indoor Magnetic Charging Cable?
Not sure which cable you mean.
If this is the magnetic cable used with Ultra/Pro3/Pro4 then it's 5v/2a
The charger that I have for the microUSB cable is 5 v/1.8a and 9 v/1.1a
Arlo Ultra 2
Prima di acquistare
