I have an Arlo Base Station VMB 5000 and 4 Ultra2 Cam (2 inside and 2 outside).
It is impossible to connect the 4 Cam because of distance and thick walls.
Is it possible to add (on the same network) a second Base Station for the 2 outside Cam?
Thanks.
Yes you can as long as the second base has access to an Ethernet connection. Many wifi extenders and Powerline extenders have one. You can then remove the camera's you want from first base and add them to second.
Arlo Ultra 2
Prima di acquistare
