- Email to a Friend
- Email to a Friend
Good evening @Augie416,
Thanks for confirming the steps you took to get the Modes tab back after the fix was deployed. Your participation is greatly appreciated!
Best Regards,
Christine
____
Please click
- Email to a Friend
- Email to a Friend
This morning when I selected disarm on my android phone, the white box came up (Setting Mode...) and it won't go away and I can't select anything else. I tried unplugging the modem. That didn't affect the phone. How do I get rid of this box so I can operate Arlo? And how may I avoid this situation again?
- Email to a Friend
My mode tab is still missing (Samsung Galaxt Tab S2). Reinstalled the app & restarted the base station - no luck. Help please.
- Email to a Friend
- Email to a Friend
The MODES button just disappeared on me today, on an Android phone. Additionally, the app keeps flickering and blinking, so I cannot click on ANYTHING. The Arlo posts indicate this problem has been solved, but apparently not. What can I do to fix or restart? Thank you
- Email to a Friend
- Email to a Friend
I've had the flickering app issue on Android where it seems to be changing screens quickly so you can't log in. I've been able to break out of it by repeatedly hitting the Home button. I don't have a solution - can't remember if force closing and clearing the cache had any effect but it was a short-lived problem.
- Email to a Friend
- Email to a Friend
- Email to a Friend
Right now using a browser is likely the best workaround although there may be problems with that, too.
- Email to a Friend
I still have this problem, I have uninstalled the app, restarted the base(from the webpage) reinstalled the app, still no Mode in the app! Please rollback or let us know what version we can use to have the Mode tab available again. I use this feature every day, at least a few times per day!
Samsung S8
Android version: 8.0.0
Security patch lvl: April 1, 2018
App version: 2.5.0_21265
Base station:
SW: 2.5.0.885_21333
2 Arlo Pro 2 cams and 2 Arlo cams.
Arlo Pro 2 info:
HW: H3
FW: 1.125.8.0_19174
Arlo Info:
HW: H7
FW: 1.2.16720
- Email to a Friend
Samsung S8
Base station:
SW: 2.5.0.885_21333
Arlo Pro 2 info:
HW: H3
FW: 1.125.8.0_19174
Arlo Info:
HW: H7
FW: 1.2.16720
- Email to a Friend
Do you know how to fix this ?
- Email to a Friend
Thankfully, the latest app update for my android device has solved the unreliable geofencing issue and also the modes tab issue. However, seeing that a number of people here are having very strange issues, I'll share a workaround I learnt from another user here on this forum.
I used APK Mirror to find an APK of the Arlo app. I found the June 2017 version worked best for me. Geofencing worked a treat, 100% reliability I found in my time using it again recently. Modes tab worked fine. The only problem was the fingerprint log in didn't work. Older versions suffer from the "session ended" problem. However on my phone I found it did not affect geofencing, the app remained active in the background.
To install the APK, first uninstall the Arlo app. You also need to have "allow unknown sources" enabled in your settings. For thoes who don't know where that setting lives, search the web for instructions. You'll also want to disable auto-update for the app. Go to the Google Play app, go to my installed apps, go to Arlo, and up the top right, click the 3-dots for more options, and disable auto-update. This will only disable auto-update for Arlo and your other apps will keep updating if you have auto-update enabled for all apps. When you've done this, keep an eye on the forums for new releases in case the app is fixed. If you keep the APK on your phone, you can try any new version of the app anytime and if it sucks, just roll back by reinstalling the old Arlo app from the APK.
My only concerns are security ones, but I feel that if you have the lastest security patch for Android, the risk is minimised. Maybe someone can contribute more to this, please.
FYI, I didn't have to do any restarts, clearing of data/cache etc for the rollback to work. Nor did I have to do that for the new version to work on my phone (I'm on a Moto G4+, Android 7). Ensure you have battery optimisation switched OFF for the Arlo app, so geofencing works all the time (and notifications). I have found that with batt optimisation on, geofencing and notifications are very unreliable.
Good luck everyone... My experience with Arlo has been absolutely RUBBISH. I figured all this out from other users. I'm even in touch with a "L3 support engineer". He's been silent for weeks now. I've just given up on him. Arlo is the last Netgear affiliated product I'll be buying. Ever.
- Email to a Friend
STILL CANNOT SE MODE IN THE ANDROID APP!
Tested powercycling the Base Station, deleted and reinstalled the app. No Mode setting in any of my Android devices!
It´s extremely annoying to see that Netgear reports that the problem is solved when so many users tells them it´s NOT!
- Email to a Friend
Try using a browser in the meantime since it seems to work better.
- Email to a Friend
Not very helpful!
I am controlling the cameras either with a surf pad or with my phones. Browser means I have to use a PC which I am not in the habit of carrying on me.
Cannot understand why Netgear took away the Mode settings from the Android app, a very severe defect for the Arlo system.
- Email to a Friend
They didn't take it away - it's a bug. I have the Mode tab in my Android app but not everyone does. You can try reinstalling the app or use a mobile browser set to use the desktop version of the Arlo site. I'm trying to give you workarounds while things are AFU.
- Email to a Friend
Thanks’ for trying to help, o Guru, appreciated :-)!
Already tried reinstalling and/or installing the app and using browsers on several Android pads and phones, no luck!
So BUG it is and it appears to have been bugging me and other users for weeks without being solved by Netgear.
I made the usual mistake one does when a community Forum is populated by knowledgeable and professional users. It sometime helps but one should instead directly report any problem to Netgears support.
Strange enough though, the answers I see people here in the Forum are getting from those users gives a more professional impression then what I have felt when in contact with Netgear Support ;-)!
Bought my Arlo units thinking they were a Security System, the impression I now get is that Netgear regards them as a toy!
- Email to a Friend
There's a new Android app available - is that working better?
- Email to a Friend
I still have the same problem with all our Android devices (e.g., Samsung S8/S9 and Tab S3) using the latest Android version 2.5.1_21471 on two base stations (firmware 1.10.0.4_20963, in Sweden) with Arlo Pro and Arlo Pro 2.
- Email to a Friend
Still not working for me on my Galaxy S8, android 8.0
I've tried to reinstall it twice now without any luck.
When will you fix this issue??
Can't even change the "shedule" on my computer
- Email to a Friend
