- English
- Arlo Forum Discussions
- Arlo Stories
- Re: RESOLVED: Arlo Base Station Appearing Offline ...
Hello Arlo Customers,
We are aware of a reported issue for some customers where the Arlo Base Station is appearing offline. We are actively investigating this issue and working to resolve it.
If you are currently experiencing this issue please reply to this thread with the following details so we can further isolate the issue:
Base Station firmware:
Device type showing offline (Arlo, Arlo Pro, Arlo Pro 2, Arlo Baby, Arlo Q, etc.):
Internet Service Provider:
Exact error message:
The application used (iOS, Android, Web):
We apologize for the inconvenience,
Arlo Team
Thank you! I had tried this remedy shortly after the system went crazy. I just followed your steps again and my system now seems to be working again.
NEVER MIND SUPPORT...I have taken the advice of another USER and I believe that my system is finally working after 48+ hours.
My Arlo base is still acting bricked, following a 24-hour update cycle.
What did you do? Ours is still saying offline. Its getting very frusturating!
i had experienced the same issue too. I solved it with a factory reset but i agree with you that it's unacceptable!
It's the second massive offline in 3 months (i bought this system 4 month ago).
I surely sell it and discourage everyone i know to buy this system.
Hi,
As others have recommended I private-messaged one of the moderators with the serial number of my base station last
evening, and this morning I now have full functionality of my system; base station is online, recording videos, etc...
Thank you.
-John Ayres
Arlo/netgear
internet provider: talk talk
base station offline
please check internet and power connected
application used: iOS
been offline since 14/5/18 done everything except
full reset
is the system faulty? Do I return for refund? Been running fine until this...
My system had finally started working ok. Now, the Push Notifications have quit again.,
So I followed all the steps previously outlined..of deleting everything in the system, ...including the base and reinstalled everything...and it’s working now.
Even after calling support..which sucked...she had no answers...so I’m very grateful for this post.
I was having the same problems others have been experiencing with base station appearing offline. This seemed to get fixed, but really, they still have problems. I've noticed the motion sensing is no longer reliable. There is still an intermittent "base station off line" message and other messages about not been able to connect etc. It's basically kind of working, but not really as it should. Very annoying.
Still showing offline 4 days after stopping
Hi
My basestation is still offline for the 3 day. On Tuesday I submitted a reply including the serial number of my basestation in this thread.
Let me know if I shall submit the serial number again and how to do it so that you see it this time.
This situation is totally unacceptable!!!
Rgds.
Kjell
iOS, serial num 48e46c7fa392c
My ARLO VMB4000r3 continues to show as offline on my android app since the latest firmware update. I have cylcled the power, synced the device etc etc. All the bars show green...please le me know what to do at this point. I have cox cable.
Thanks, Brian
Without any support at all from ARLO on this problem, this morning I decided that I couldn't wait for them any longer. Having removed the basestattion from my account a couple of times, alarms finally began popping up. I had to set up the geofencing part again, and now all seems to be working ok.
Until a week ago, I have always recommed ARLO to family and friends, but that will NEVER happen again !!!
Rgds. Kjell
Base station been off for a week.ser number is 48e46c7fa392c tried factory reset and now can’t reconnect my cameras.and still off line.how can I return the every thing back to netgear as the warranty is out,and they bricked it?
I suspect it's not bricked. What do you mean by "reset"? Some folks think a power cycle is a reset but that's not even close. Removing everything from Settings, My Devices and/or using the rest button on the base until the LEDs flash amber is a reset. If that's what you've done, be sure nothing is in Sttings, My Devices. Use the Add Device button in the Devices tab to claim the base. Sync the cameras.
Yeah, jguerdat, I'll jump in and answer that...
Bricked, as in the power LED has been flashing at one second intervals for a week and the base station is unresponsive to **ANY** attempt to reset the hardware, using the proscribed techniques. (i.e., pressing and holding the reset button for 10s+ until the LEDs flash amber and the hardware resets)
I have been dwaling with support for the better part of a week and received authorization to get a replacement and RMA the brisked hardware. Imagine my surprise, when I was informed it would cost ***ME*** $17 to return the hardware Netgear bricked!
Needless to say, this is the last time I purchase *anything* from Netgear and I will give them poor reviews at any and all opportunity.
You're not the one who said his base was bricked. However, if the power LED is blinking as you say, it's either the power supply or the base that has an issue. A hardware problem like that can only be fixed by opening a case with support or, if within the store return policy, swapping at the store. Since you've received the RMA authorization, you've got the solution. I do agree that having to pay shipping for a faulty device that cost this much is an unnecessary slap in the face.
I can now see my base online but my motion detecting and recording are not working.
Base Station firmware: 1.10.0.4_20963
Device type showing offline (Arlo, Arlo Pro, Arlo Pro 2, Arlo Baby, Arlo Q, etc.): Arlo
Internet Service Provider: Spectrum
Exact error message: No message, Motion detection not working and cameras not recording
The application used (iOS, Android, Web): Android and Web
Use the browser and check your modes, rules and schedule. I'm still having issues with things getting reset/changed.
The mode is active and has been since this started with the base update on the 15th. Rules are the same default for that mode. I even got a new phone This weekend and have a fresh copy of the app. These cameras are junk if they don't work so I'm going to attempt a refund based on defective product and if that don;t work, I'll contact the BBB.
I’m a user of Arlo Pro in Sweden. Had BIG trouble since updating the Arloa app last monday. I just talked to Swedish support. According to that guy Netgear have now solved the issue, and it is now at Apples table for their approvement. So hopefully a new update is soon available.
I’m a bit sad over the bad informatin from Netgear on the community.
Michael
Here we go again. Mine had been working ok for a few days. Not the Push Notifications isn't working again.
Just found a report from February 2018 that Netgear is planning to spin off Arlo and do an IPO offering. Bet it doesn't do too well with these problems being communicated. Would spin pretty flat now.
