Arlo Go LTE Security Camera now with AT&T!
  • 0 Replies
  • 2910 Views
  • 1 In Conversation
AngeloM
The wait is over. Arlo Go, the world’s first wireless mobile LTE enabled HD security camera, is now available on AT&T mobile plans.
Arlo Go is similar to our brilliant Arlo Pro in that they are both wire-free, weatherproof, and come with rechargeable batteries. However, while the Arlo Pro works anywhere within range of your WiFi network, the Arlo Go is more mobile.  It can be mounted anywhere you have an LTE signal but are out of range for WiFi, like in your RV, or  at a vacation home, on a boat dock, farm or construction site… really, anywhere you can imagine.
And now that Arlo Go is supported by AT&T 4G LTE, as well as by Verizon, you can monitor your possessions from anywhere, no matter how far away, rain or shine, hot or cold. Where would you want to use your Arlo Go?
Make sure every angle is covered, with Arlo.
This was posted on the NETGEAR blog.
0 REPLIES 0
  • 0 Replies
  • 2911 Views
  • 1 In Conversation
