iOS needs a specific setting to set notification sound effect
In android, you can natively change the notification sound effect of an app thanks to the notification channel API exposed to developers my default.
in iOS , Arlo needs to manually program an option for us to set the notification sound effect for iPhone users to do the same.
Can we get that or at least a unique default notification sound that is specific to Arlo? It’s easy to miss Arlo notifications if it’s using the same default chime as every other lazy developer who doesn’t implement custom notification sounds/options.
As a camera securely system company, you should do better in this regard especially.
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
