When camera 1 catches motion, camera 1 & 2 should record but only one records?
When i set up. When camera 1 catches motion, camera 1 and camera 2 should record, only camera one records?
I have the new smart hub with arlo pro 2 cameras. But only the camera that detects motion, are recording.
What ever i do i dont get 2 captions?? I have activated arlo smart plan for both cameras also.
Have you verified that your mode still has the rules that cross trigger and that it's the active mode? Rebooting the base may help, too.
I have. Now installed my pro 3 cameras and trying to test them out to se if they want to record for each other
This is a bug that needs to be fixed. And it may be the new pro3 smart hub.
It may be a software problem but be sure to try setting the mode and rules up using a browser to see if that makes a difference. I've seen weird things using the app that a browser doesn't introduce. Create a new mode to make sure it's a fresh setup.
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
