VMS3130 not working anymore
  • 5 Replies
  • 2632 Views
Gddr
I cannot connect to my cameras anymore and nothing has changed from my network nor on my camera setup. Can you provide guidance?
Arlo Smart Home HD (purchased in 2017)
5 REPLIES 5
@BrookeN is this another case of backend syncing being needed?
BrookeN
Actually this is not, it appears this user has the Arlo Gen 3 Cameras.
@Gddr are you seeing them as connected within your app just offline? Or is there a certain behavior you are seeing? Can you provide more information.
Gddr
Hi, thank you for supporting. I see them offline with the following message:
Your Arlo device appears offline
Please make sure it's powered on and connected to the Internet.
All LEDs are green on the router and cameras are paired with it as well.
BrookeN
Have you already tried to do a reset on the cameras? If not that would be the next step you would want to try.
https://kb.arlo.com/000062880/How-do-I-factory-reset-and-re-sync-my-Arlo-camera-Arlo-Secure-4-0
Gddr
Full reset and removal of devices fixed it. Thank you.
