The worst purchase I ever made ...
This system is the worst purchase I ever made ... Nothing works Batterys dead in 3 days ... Cameras will not stay loaded ...
Hi @Jose50
How far are your cameras from the base station? Have you moved your router a bit further from the base station & vice versa?
Worst cameras ever don’t work or won’t record more than half the time. Cameras are useless just like trying to contact support help useless. Don’t waste your time buying any arlo products
Cameras are straight garbage and you know it. I’ve contacted my internet provider and they checked everything out and said the problem are your cameras and also said they had many customers with these same cameras with same problem and said to contact arlo support which I told them I called support and blamed my internet provider for the problems which the problem is clearly with arlo products
I had night owl too. Night owl actually works unlike arlo
Don’t matter where you move base or router cameras don’t work or record more than half the time. Make a better product before putting out for sale and screwing buyers over with no way of fixing problems
Can you provide a bit more context regarding the issue you experience with your cameras?
Do you have a case number regarding the Arlo baby camera I can review?
Thank you
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
