Modes - Automations Help
  • 2 Replies
  • 1355 Views
jbhardman2
I am wondering if it's possible to setup an automation scenario. I can't figure it out in the App.
I have setup scheduled routines so that every morning at 6:30am my "Standby" mode is activated. That's about when the family starts waking up and becoming active in the house. Every night at 11pm mode is changed to "Arm Home", this is when we are usually all in bed and I want cameras recording.
I also have Arrive/Leave set so that when every registered location device leaves, system is "Arm Away". When one registered device arrives "Standby" is activated.
The issue I have is when we are gone for extended time periods. Like vacations. We leave, and the system goes to "Arm Away". Then, at 11pm, it goes to "Arm Home", then at 6:30am it goes to "Standby". And fluctuates between "Arm Home" and "Standby" every day until we return.
I want to disable the Scheduled changes (morning/night) when all registered devices are out of range. Only run the scheduled changes if someone is "Home".
Any way to do that?
You need to go into the "Arm Away" mode, and disable the schedule automations there.  Scroll down to the bottom of the "Arm Away" Mode settings screen (past all the camera rules) and you'll see the automation enable/disable controls.
jbhardman2
Amazing. I completely misunderstood what that meant. I'll give it a try.
Thanks!
