  • 1658 Views
Luke33
If I get a subscription plan for one system and then add two more systems on the same account will they be included on that same plan?
As long as they're on the same account as the US one, I believe that any subscriptions would carry along. Only if you used another account relative to the new country would there be an issue.
Luke33
An example: I have a system in Florida with a subscription plan. I then install and second and third system in a non-suported country but I add it to the same email address that has a plan in Florida. Will the two other systems then be covered under the same plan or will they fall off the way-side and not be on any plan?
Luke33
OK, Thank you, I will give it a try then. 🙂
