E911
  • 2 Replies
  • 2506 Views
Andyman22
Set up my first Arlo cam and e911 service in the process. But after seeing it on the notification I am worried about accidental usage.
How do I disable e911 feature on the essential model? Thanks!!
dcfox1
Good question. I never activated so can't answer it but when you go to settings>E911 what does it show? When I click that setting I just have the option to set up since I never set it up.  Out of curiosity i did search and appears you can't but they were old post. Mabey a moderator or someone else can answer it.
Holoviak03
I just did the same thing. Did you get any good response from Arlo? I know I'm going to accidentally hit this .
