  • 1 Reply
  • 1019 Views
DWBTRB
I have read a post on this topic. If you want to delete data on an SD card in a VMB5000 hub and don't need to keep any data, you can simply format the disc using the arlo app. If you do want to save some data, you can use the app and download the pictures or videos to your device.
DannyBearAgain
Just to add that the arlo app access is limited to the last 30days so you would still need to use a pc to access any recordings on the card prior to last 30days.
