  • 56 Replies
  • 8785 Views
alex_loo
Virtuoso
Virtuoso
This is very weird and already the 3rd consecutive night happening this.
I have this time routine switching to ArmAway every 1130pm, followed by no notification.  Running Perfectly perfect so far.
And then these 3 nights, it still switched to arm away, but then
  • Notification about motion alert of 1 of my 3 cameras
  • Recording with that camera ( and there was no motion at all)
The camera in context happens to be the last camera that is armed up.
Anyone experiencing something similar?
Alex.
56 REPLIES 56
@jguerdat wrote:
I'm now on (Android) 6.2.8 with GF working 100% for a while now.
@alex_loo - I started monitoring this again a few days ago (iOS, only one geofencing device). Not a lot of occurrences yet.
The system triggered properly on all the "Leaves", but only one "Arrive" resulted in a trigger.   The other two "Arrives" were missed.  So not anywhere close to 100% for me.
This was with 6.2.6 - I just updated to 6.2.8.  Hopefully that will do better.
alex_loo
Virtuoso
Virtuoso
@alex_loo wrote:
@BrookeN wrote:
@alex_looare you still seeing this same behavior?
hi @BrookeN , yes the issues never improve at all.
@BrookeN , I'll add up my failing cases here, if you or anyone is interested:
  1. Just yesterday, my device and wife's device were leaving, but ARLO didn't switch to ARM AWAY and it should have, according to my away routine
  2. While both devices were away and ARLO was ARM AWAY, and then wife's device was back.  ARLO did NOT switch to STANDBY, but it should have, according to my ARRIVE routine.
  3. As the next scenario of number 2 above (ARM AWAY, wife device home already, my device still away), when my device is back, ARLO did NOT switch to STANDBY, but it should have, according to my ARRIVE routine.
  4. [2025.08.03] ARLO was ARM HOME.  Both devices leave together.  ARLO stayed at ARM HOME, incorrectly.  It should have changed to ARM AWAY.
Months ago, I submitted data log on similar issues, but have heard nothing.  And again, such basic geofencing has NOT been working, since more than 14 months ago, when I first owned the whole system.
With trepidation in my heart, a couple of questions:
1) You are on Android only, right? ( @StephenB is on iOS)
2) You are still on a rather old version of the app, correct?
You can use a file manager such as "File Manager +" to back up your existing app, remove it and install the current version on both phones to see if that works. If not to your liking, you can then revert back to the backed up version.
alex_loo
Virtuoso
Virtuoso
Negative.  I have both OS here.  My device is on android 16.  Wife's on iOS 18.5
Negative.  I have been forced to update to this 6.2.8 here, more than a week ago.
I won't waste my time trying this and trying that.
a. ARLO support has contacted me for data log looking into geofencing issue.  @BrookeN  has also confirmed in this community that DEV team is looking into this.  So far I have NOT heard any news regarding any version fixing geofencing issue, so I would assume GEOFENCING IS STILL OUTSTANDING ISSUE AND ARLO IS STILL LOOKING INTO IT.
b.  I have been told by "superusers" that they "do not work for ARLO", so won't bother any non-official suggestion trying this and trying that, understanding that ARLO has simply made zero fixes to geofencing.
Alex
FYI, I've also missed an Arrive with 6.2.8.  So still not working correctly.
So far it has not missed any "Leaves", which is puzzling.
alex_loo
Virtuoso
Virtuoso
(new #5)
  5. [2025.08.05] Both devices are away, and ARLO is at ARM AWAY.  When both devices are then arriving home together, ARLO stayed at ARM AWAY, incorrectly.  it should have switched to STANDBY, according to the geofencing routine setup.
BrookeN
@alex_loo can you please go into your wife's phone and under edit Geofence make sure that your wife's location permissions are on. If they are off it will show like a triangle with a line through it and it will state needs location permission.
alex_loo
Virtuoso
Virtuoso
@BrookeN wrote:
@alex_loocan you please go into your wife's phone and under edit Geofence make sure that your wife's location permissions are on. If they are off it will show like a triangle with a line through it and it will state needs location permission.
hi @BrookeN , where is this "edit geofencing"?  Nevertheless, I have configured the following on wife's iPhone, since 12+ months ago:
  • ARLO app has permission to iPhone location service (ALWAYS ON and "Precise location")
Do you have updates regarding any ARLO app fix, over these 12 months?
Alex
alex_loo
Virtuoso
Virtuoso
(new #6 #7#)
  6. [2025.08.06] ARLO app was ARM HOME.  Both devices were at home.  Then only my device left home, but then ARLO switched to ARM AWAY, incorrectly.  It should have stayed at ARM HOME (since my wife's device was still home)
  7. [2025.08.06] ARLO app was ARM HOME.  Wife's device was home and my device was away.  Then my device arrived home, but then ARLO stayed at ARM HOME, incorrectly.  It should have switched to STANDBY, according to my geofencing routine.
alex_loo
Virtuoso
Virtuoso
as a side info to show that wife's phone has location permissions in place.  Today (2025.08.06) ARLO was ARM AWAY, and both devices were away.  Then wife's device arrived home, and then ARLO switch to STANDBY, correctly (well for this time) following the routine I have set up.   This shows that the device location permission settings have been well in place.
Alex
alex_loo
Virtuoso
Virtuoso
(new #8)
  8. [2025.08.06] This is the same issue #7 repeated again, on the same day.
alex_loo
Virtuoso
Virtuoso
(new #9 #10)
  9. [2025.08.07] This is the same issue #6
  10. [2025.08.07] This is the same issue #7
BrookeN
I have been passing this information onto our development team. As well as the logs that were provided. I will provide an update as soon as possible.
alex_loo
Virtuoso
Virtuoso
thanks.  I'll report incidents here.
@BrookeN , any chance we could:
  • be updated here regarding the troubleshooting progress, say on monthly basis?
  • be shared about the ball park date in development team's mind?
Alex
alex_loo
Virtuoso
Virtuoso
(new #11)
  10. [2025.08.07] This is the same issue #7, again
  11. [2025.08.08] This is the same issue #7, again
alex_loo
Virtuoso
Virtuoso
(new #12 #13)
  12. [2025.08.09] This is the same issue #6, again
  13. [2025.08.09] This is the same issue #7, again
alex_loo
Virtuoso
Virtuoso
(new #12 #13)
  14. [2025.08.14] ARLO app was ARM HOME, and wife's device was away while my device was home.  Then my device left home, but ARLO stayed at ARM HOME, incorrectly.  It should have switched to ARM AWAY.
  15. [2025.08.14] ARLO app was ARM AWAY, both devices were away.  Then my device arrived home, but ARLO stayed at ARM AWAY, incorrectly.  It should have switched to STANDBY, according to my geofencing routine.
BrookeN
Geofencing with scheduling is still being investigated by our development team. I appreciate all the information you have sent. I will reach out soon.
alex_loo
Virtuoso
Virtuoso
(new #16)
  16. [2025.08.15] This is the same issue #4, again
alex_loo
Virtuoso
Virtuoso
thanks.  If upcoming app version is fixing any part of geofencing, please let me know.
Alex
alex_loo
Virtuoso
Virtuoso
(new #17 #18)
  17. [2025.08.19] ARLO was ARM HOME, wife device was at home and my device was away.  Then wife device left home, but ARLO stayed at ARM HOME, incorrectly.  It should have switched to ARM AWAY.
  18. [2025.08.19] ARLO app was ARM HOME, and both devices were away (this is not my typical use case scenario).  Then my device arrived home, and ARLO stayed at ARM HOME, incorrectly.  It should have switched to STANDBY.
alex_loo
Virtuoso
Virtuoso
(new #19 20)
  19. [2025.08.19] This is the same issue #14, again
  20. [2025.08.19] ARLO app was ARMH HOME, wife device was away and my device was home.  Then wife device arrived home, but ARLO stayed at ARM HOME, incorrectly.  It should have switched to STANDBY.
alex_loo
Virtuoso
Virtuoso
(new #21)
  21. [2025.08.20] This is the same as issue #4, again
BrookeN
Thank you for this information. The development team is working on a update that will fix Geofencing working with the schedule. I do not have an exact eta on that as of yet, however it will be in the near future. I will update you as soon as that is available.
alex_loo
Virtuoso
Virtuoso
Alex
