Can I get Arlo Smart for 1 Doorbell camera?
  • 1 Reply
  • 3149 Views
Eltee
I have a system using a video doorbell and 3 cameras. My trial period ends soon and I am deciding upon if I should subscribe. I am only interested in having the doorbell on the Smart system, the other cameras are mainly to keep an eye on the dog, etc. Since the subscription is priced per camera, can I subscribe with only the doorbell and leave the other cameras off the subscription?
THANK YOU for any input.
dcfox1
You can use a single plan for the doorbell or the up to 5 camera plan to put the others on. Not sure what model the cams are but if newer then Pro2 you need a sub for cloud recordings if you want that.
Arlo subscription plans and cloud recording
dcfox1
