For 3 days the recording does not follow the parameters set for sound and motion. For over a yr this is what it has been set to. I have removed and added cameras. Turned on off base station. Checked connections. Even factory reset. Also uninstalled install the app. No good. I even added the Arlo Smart hoping it would fix it since it appeared on my settings tab since this problem started. Still no fix. The green middle light flickers for a second on and off for a few minutes before the camera will actually start recording. I love my camera but it’s been 3days! I’ve about had it especially since I can’t seem to get thru to someone to help.
Have you tried to reboot the camera by removing & inserting the batteries? you can also try a reboot of the base station as well.
Have you tried to reboot the camera by removing & reinserting the batteries?
Have you verified your camera settings in Settings, My Devices as well as in your modes and rules compared to the working camera?
Keep responding to that case number so it doesn't time out and get closed.
animal
Arlo Q Series
detection
e911
notifications
Servicio y Almacenamiento
