Two security lights and one camera and modes
  • 1 Reply
  • 1374 Views
Schnoomom
Hi! I've tried to figure this out but am struggling.
I have a Pro camera positioned by the shed.
I have two security lights: shed and garbage.
I have successfully set a custom mode that says if the shed light detects motion, it turns on and begins recording.
I now just want the garbage light to be set to motion and it turns it on (no recording).
I don't want the garbage light to come on during the daylight.
I do need any motion at the shed to set the camera to record no matter day or night.
I don't want to set the system to Armed because I always want the shed motion to trigger recording but I don't need the garbage to go on whenever there is motion.
I hope this makes sense. And I hope someone can help me figure out these settings.
Thanks!
First thing is the lights will NOT come on in daylight ( built in light sensor ) tho they will detect motion
You must armed the bridge sytem for the lights to be active and/or the camera.
So you can either have light detect motion and start the camera or the camera detect and start the lights..I find the light tend to be a bit more sensitive to motion.
So I would set up a mode that arms light A and motion triggers that turns on cam A to record and Light B
hope this helps
  • 1 Reply
  • 1375 Views
