Solar Panel Charger (VMA5600) Looking for a Cable Extension with Magnetic connectors at both Ends.
  • 1 Reply
  • 3387 Views
cammot
I am using the Solar Panel Charger outside with my Arlo Ulra.  The cable that is built in to the Panel is not long enough !.  I need to find a cable extension that has magnetic connectors at both ends, so that I can use it on my existing setup and allow me to move the Panel further out so I can capture better sunlight throughout the year. It seems this kind of cable does not exist!. Has anyone found a solution to this need?
RafS
You're probably not going to find one that connects to the end of it but I would say, cut it in the middle, extend to whatever length you need and splice it back up.  I would not go too long since I'm not sure if there would be power loss or not enough power getting through over long runs.
  • 1 Reply
  • 3388 Views
