Security light AL1101
  • 4 Replies
  • 4784 Views
MoPro
Security light not connected to system, Following directions for adding device, when inserting the recharged battery the light does not flash and it will not pair to bridge.  Can not add this device to system. Security Light AL 1101, Approximately 2-3 years old.
MoPro
Typo: should say "will NOT pair"
If you need to pair it as if new, you also need to remove it from your account before that will work.
MoPro
Thank you, I have done this previously and it worked for a short time.  When it stopped working and showed to be off line I tried to do this again but the light would not flash when the fresh battery was installed.  I assume the light is dead, it was purchased in 2019 but really was not very active.  Can these be repaired?
No repairs are possible and the security lights are on the EOL list. You may want to use a spotlight or floodlight camera instead.
  • 4 Replies
  • 4784 Views
