One Bridge, two Lights: How to create the following simple mode and make it work?
  • 1 Reply
  • 1167 Views
Uclaby7
Question:  How to create a mode where one light senses motion, turns itself and other light on.
Similarly, other light senses motion, turns itself and first light on.
Is the above attainable?
Yes...but you really have to understand how modes and rules work...
you you have two lights A & B
in one new custom mode ( cause only one mode can run at a time ) start off with if A senses A turns on ... Then save the new mode.  Go back and edit it to add the following rule A senses B turns on.
Then add the opposite....as a new rule.
when done it should be like;
A senses A on
A senses B on
B senses B on
B senses A on
  • 1 Reply
  • 1168 Views
