Maintaining a light color
  • 1 Reply
  • 2929 Views
N8star
Question I’m hoping someone can help me with.  On the app I set my security light to a certain color and brightness.  Afterwards If I turn the light on manually it goes on with these color settings but if goes on by being triggered by motion it goes on white and 100%.  Anyway to set it so it comes on in my set color when triggered by motion ?   Thanks.
Try to set the color on the web    https://my.arlo.com
I find it much more stable.
After you pick the color and one of the three options (white , color, multi ) you shold see the prgm save automatically.
then test
If it doesn't save I would reboot the bridge ( unplug and replug ) test
Or at last if ng, remove light and bring back as new
  • 1 Reply
  • 2930 Views
