Help re-onboarding a security light
  • 2 Replies
  • 2286 Views
JPA1
  • Removed a security light and can’t get in to add back on in add device
Make sure it's gone from your account and then follow this procedure:
https://kb.arlo.com/000062438/How-do-I-factory-reset-and-re-sync-my-Arlo-camera
EzellBilla58
If you can't add your security light back to your Arlo account, try checking the status of the light, the network connection, and your Arlo base station. If that doesn't work, remove and re-add the security light in the app.
  • 2 Replies
  • 2287 Views
