Do I Need Another Bridge With A New Arlo Security Light
If I already have one Arlo Security Light and one bridge, do I need another bridge for the next light I purchase? I have 2 Arlo Pro cameras and a base station as well.
Anew light will connect to the existing bridge with no problem.
Just makes sure that it is within range of the bridge.
Just another user
Adding Bridge gives you added range, but also added programing options to trigger lights and cameras. We are running 3 brides and 6 lights now. When someone gets in suspicion territory, usualy 2 lights and 3 cameras will trigger, so no matter which way they go they will smile
