Arlo security light time setting
  • 2 Replies
  • 2331 Views
jp1250
Has anyone ever experienced the need to have the on time be less than the 5 minutes that the app has the minimum setting for?
steve_t
Master Master
With motion activation or cross triggering, the duration is between 10 seconds and 2 minutes. With manually activating the light it's able to be set between 5 minutes and indefinitely on. I guess if you want something less for manual activation or more for motion activation, post it in the ideas exchange section and hopefully enough people will upvote it to make it happen
steve_t
Master Master
michaelkenward
Sensei Sensei
Sensei
And is under your control via the rule that turns the light on.
Just another user
  • 2 Replies
  • 2331 Views
