Arlo Security light - No motion detection
  • 2 Replies
  • 2363 Views
LucyGoosey
Hi, I'm having the "No Motion Detection" with the Arlo Security Lights. It seemed to occur just after the Arlo app change. Was there any solution or resolution to this issue? Thanks
BrookeN
Can you please go through these steps and make sure everything is set up properly within the settings
https://kb.arlo.com/000062889/How-do-I-enable-or-disable-motion-or-sound-detection-on-my-Arlo-device...
BrookeN
LucyGoosey
Thank you for quick reply. Everything is working now (motion detection).  The new Arlo app
is a little different setting wise. Thanks again.
  • 2 Replies
  • 2364 Views
