  • 4 Replies
  • 7508 Views
Ayrton
I installed 3 lights to add to my cameras.
All went well with my installation except one light won't come on at night (Dark out) when I can turn it on manually and the motion test is good and also is connected to bridge???
My 2 other lights work perfectly..
Any help appreciated.. Thanks, Ayrton
Battery 100%
Hardware Version: AL1101r4
Firmware: 3.2.25
Same for all three lights
Ayrton
Fixed!
Light intensity was Turned down. Reset to 100% and all is good...
Thanks all for your response...
Is there a mode with a rule for that camera? What mode are you using?
Ayrton
No Rules set.
Units out of box new!
Verify that there's a rule for the camera in the Armed mode. If so, remove the light from Settings, My Devices and resync.
Ayrton
Fixed!
  • 4 Replies
  • 7509 Views
